Yokomo官方公布了全新BD7 1/0电动房车的照片。车架的重心进行了优化,马达位置向中线移动了9.5mm, 车架上的设备分布更对称,能够提升车架的扭动性能。浮动可调式舵机固定座、完全分离设计的悬挂臂码和大容量避震器都出现在BD7新车上。还没正式上市已经在全球各地大赛中进行测试和实战,在上月刚刚结束的世界赛上BD7新车轻松进入A组决赛,战斗力有目共睹! ■Competition 4WD belt drive touring car ■Left/Right symmetrical construction for optimal chassis flex ■Split aluminum suspension mounts(front-rear, and rear-front) ■Motor positioned 9.5mm further inward from previous ■Front aluminum solid axle ■Rear gear differential ■Lightweight molded belt-tensioning cams ■Front and rear sway bars standard equipped ■Large volume aluminum oil-filled shocks ![]() ![]() ![]() ![]() |
