Hot Bodies R10油房
12-11-12 11:39| 发布者: rcfans| 查看: 6330| 评论: 4
Hot Bodies推出R10 1/10油动房车,属竞赛级产品。HB对R10新车进行了长时间研发和测试,正在泰国举行的IFMAR油房世界赛R10也会亮相。高质量的一体化传动轴、强化铝制皮带轮、碳合金推杆、四片式引擎座完全兼容Novarossi和OS引擎、高精度刹车碟和可快速调整的Ackerman角度设定都出现在R10新车上。R10的真实战斗力还有待考验,相信R10会让玩家多了一个好选择。->点击这里进入HPI品牌专区参与互动
http://cdn7.rccaraction.com/wp-content/gallery/hot-bodies-r10-nitro-touring-car-kit/108382_003p.jpg?8a12f1
http://cdn9.rccaraction.com/wp-content/gallery/hot-bodies-r10-nitro-touring-car-kit/108382_000p.jpg?8a12f1
http://cdn4.rccaraction.com/wp-content/gallery/hot-bodies-r10-nitro-touring-car-kit/108382_002p.jpg?8a12f1
FEATURES:
  • Centralized lower weight distribution provides superb balance with increased transitional agility
  • High quality universal driveshafts front and rear for the best drive efficiency
  • Titanium tie-rods, rear camber links, middle shafts and rear sway bar joints
  • Hard coated aluminum pulleys (except the rear diff pulley)
  • Separate (upper and lower) bulkheads allow for quick and easy diff change and drive belt tension adjustments
  • New fuel tank equipped with EZ cap designed for least fuel liquid level change for the best fuel efficiency
  • 4-piece engine mount compatible with both OS and Novarossi type engines
  • High precision brake rotor and brake pads made from the same material used in full scale racing cars provide superb stopping power and brake feel
  • Servo saver with one-touch Ackerman adjustment system
  • Multiple suspension pivot point adjustment system allows for fine roll center tuning
  • Direct fit wing mounts on rear shock tower
  • PTFE-coated oil shocks
  • Efficient .08 module gears
R10 SPEC:
Length: 366mm
Width: 200mm
Wheelbase: 261mm
Weight: 1700g
Gear ratio:
1st=7.56:1.0 2nd=5.27:1.0
    引用 gc217 12-11-12 18:35
    nankey: 之前根本没有油房吧
    自己去查查 HB 之前还做出过油铲子那!
    引用 nankey 12-11-12 16:39
    之前根本没有油房吧
    引用 gc217 12-11-12 14:56
    HB的油房 基本能看不到人用 大比赛也是让 蛇仔 NT1 之流 踩脸道地上。
    引用 COPPELION 12-11-12 12:09
    还当是新的直销
