Tamiya TA05-VDF II限量版
12-6-6 19:52| 发布者: rcfans| 查看: 9938| 评论: 12
Tamiya(田宫模型)推出TA05-VDF II限量版漂移车。3皮带传动系统,全新的马达座能够让传动齿轮的位置降低,短身悬挂摇臂,前珠差等组件都包含在新车内。车架的整体扭动性能增强,转向幅度更大更适合漂移,和现有的VDF II车架一样,TRF避震等高性能配件被沿用在限量版新车上。本月上市!
Specifications:
Scale: 1/10 scale
Construction type; assembly kit
Terrain use: on-road
Drive-train: 4WD
Drive type: belt
Drive line: universal
Differential type: direct coupling (spool) & ball differential
Suspension: fully independent double wishbone
Steering mechanism: bell-crank
Shock damper: oil-filled damper
Shock damper material: aluminum
Tire type: not included
Tire tread: n/a
Body material: n/a
ESC: not included
ESC type: N/A
LED Light buckets: no
LED lights: no
Motor type: not included
Bearings: shielded ball bearing
Chassis material: carbon fiber plate
Sticker material: n/a
Adjustable camber: yes
Adjustable toe angles: front and rear
Adjustable ride height: yes
Adjustable gear ratio: yes
Adjustable wheelbase: yes
Adjustable track width: yes
Adjustable shock angle: yes
Anti-squat adjustment; yes
Droop adjustment: yes
Special features: triple belt drive-train, short reversible suspension from TRF416-417, TA05V2 & TB-03
    引用 绯色之门 12-6-10 20:56
    配件难买,,,,,,,
    引用 爆走控控 12-6-10 11:10
    现在不是越简单越好么?????????????
    引用 mubius 12-6-7 23:28
    我相信不久的将来会有,年度纪念版,周年纪念版,初回重制版,X色限定版,XXX人独立设定版,反正一个东西各种版,田宫的东西本人表示一直在观望,从来未出手
    引用 淹.sǐの鱼o0 12-6-7 15:17
    这货总是那么眼熟……
    引用 stone456 12-6-7 11:56
    喝汤都没米咯
    引用 极限狂飚 12-6-7 10:58
    不错 可以改中置电池。很好
    引用 轨道车的回忆 12-6-7 09:39
    是不是看起来越复杂就越好
    引用 标哥哥 12-6-7 09:29
    感觉胶件太多啦!OP都唔简单啊!
    引用 HUSTO花溪途 12-6-7 01:02
    田宫应该出车就是经典吧! 京商是否能与田宫 ...
    引用 a1204399 12-6-6 22:49
    田宫始终没出反胎车啊
    引用 7880936 12-6-6 21:25
    乱七八糟一大堆零件
    引用 erbai748 12-6-6 20:56
    哇塞了 又要多少米啊
    查看全部评论(12)
