HPI Ford Fiesta WRC遥控车
11-12-16 13:15| 发布者: admin| 查看: 14757| 评论: 27
HPI 的神秘车揭开面纱,这是一辆福特Fiesta Abu Dhabi世界拉力赛遥控车。1/8油动大比例车款,其实这类型的遥控车Kyosho一早已经有很成熟的产品,属于娱乐性较高的车型。使用WR8车架,4WD直轴传动,双碟刹,Nitro Star G3.0引擎,搭载2.4G遥控设备,福特授权制造的Fiesta的WRC车壳、米其林轮胎,外观像真度较高。整体来说,HPI这辆新车并未为大家带来惊喜,这只是一辆具有一定娱乐性的1/8油动拉力遥控车。
视频:
Features Summary
  • Pre-Assembled 1/8th scale Rally Car
  • Based on the Bullet 3.0 nitro truck
  • Nitro G3.0 High Output engine with slide carb
  • TF-40/RF-40 2.4GHz 3-channel radio system with failsafe and drop-down steering wheel
  • Powerful & waterproof steering servo
  • 3mm aluminium chassis with centralized weight balance
  • Steel flywheel for improved idle stability and low RPM response
  • 1/8th buggy 2-shoe racing clutch for optimal throttle response
  • Dual steel disc brakes
  • Full-time 4WD for excellent control
  • Efficient and tough shaft drivetrain
  • Front skidplate with durable foam bumper
  • Splashproof receiver box
  • Composite chassis braces for extra driving feel
  • Tough oil-filled gear differentials
  • Realistic Michelin gravel rally tyres
  • Aluminium shock towers front and rear
  • High ground clearance for driving on most surfaces
  • Mud guards for rear shocks prevent dirt build-up
  • 75cc fuel tank for long runtimes
  • Quick access to all critical maintenance points
  • Dual bellcrank steering
  • Cam type servo saver
  • All socket head hardware
  • Full set of rubber-sealed ball bearings
12下一页
    引用 wangzys 11-12-19 21:29
    期待!!!!!!!!
    引用 ghojd 11-12-19 00:40
    3.0的引擎有点差的
    引用 zx300 11-12-18 15:13
    车壳可以啊!壳控
    引用 免贵姓徐 11-12-17 11:47
    说实话 毒到我了。。。。。想入手 ...
    引用 nightkiss 11-12-17 11:46
    车车本身无带来惊喜,希望价格带来惊喜,这些拉力车,娱乐性非常高。
    引用 shi995800 11-12-16 21:16
    确实没什么新意~~
    引用 geniusyys 11-12-16 20:49
    hpi只要是垃圾车,视频都很帅
    引用 黄景伦 11-12-16 20:35
    18级的发动机感觉得小了,一比八最小也得21吧
    引用 xingfushiyizhan 11-12-16 20:26
    此车必火,这对于喜欢WRC的童鞋们来讲,肯定杀伤力如核武一般
    引用 jakesen 11-12-16 20:22
    视频拍的好
    引用 金属兔子 11-12-16 18:37
    这段视频拍的实在是太好啦!
    引用 无私奉献的树 11-12-16 17:56
    HPI太会做生意了,小小一个视频,毒倒多少人..............
    引用 自由大帝 11-12-16 17:53
    这下好了~~~
    可以用Bullet ST改成WRC了~~~
    引用 pc-cat 11-12-16 17:35
    明明是1/10的……
    引用 wanniyibian 11-12-16 16:55
    这就是广告的效应! 车一般 外壳好看  广告做的好点  就有人买啦     个人感觉这车可玩性要比越野大    越野太专业啦 不适合娱乐。
    引用 林四海 11-12-16 16:48
    你看看我说的吧, hpi必须是美国车壳哈哈哈
    引用 Tuzki 11-12-16 16:18
    最起码国内是冷门~
    引用 丿氵番|D调 11-12-16 15:39
    hpi的广告是越做越好了。。
    引用 ss_aa 11-12-16 15:35
    坑爹物...
    引用 毓麒生 11-12-16 15:14
    fysxbf: 京商八分之一是双速,但是车壳轮胎是亮点
    喜欢这个轮胎 肉肉的,平跑的胎太薄了,哈哈
    查看全部评论(27)
