Team Magic E4RSII 即将上市
11-11-10 18:29| 发布者: admin| 查看: 8199| 评论: 4
l      High grade woven graphite chassis
l      High grade woven graphite upper deck
l      High grade woven graphite shock towers
l      Alum. upper mounts
l      Alum. C blocks
l      Alum. dual steering arm set
l      Alum. bulkheads
l      Alum. servo mounts
l      Alum. wheel adaptors
l      ST steel universal drive shafts
l      ST steel suspension pins
l      CNC machined spur gear
l      F/R gear differentials
l      Mirror polished shock bodies
l      Titanium coated shock shafts
l      Quick release battery holder
l      Low friction ball bearings
12
    引用 zengjiutiansi 11-11-11 15:14
    他那自以为是的三皮带那? 呵呵 看来越来越老实了 哈哈
    引用 shi995800 11-11-11 12:34
    貌似避震容量大??!
    引用 cw036 11-11-10 22:54
    价钱不贵的可以考虑下啊。。。。。。。。。。。
    引用 aorixu 11-11-10 21:56
    我的G4RS都卖了  没有零件白费
