Xray推出XB808可调尾Hub
11-3-25 23:54| 发布者: admin| 查看: 4803| 评论: 0
Xray推出铝制XB808可调尾Hub,CNC制造,使用高质量的7075 T6瑞士铝材,强度和耐用度大幅提升!可对滚动中心进行调教,连杆链接有三个可选孔位,让玩家调整滚动中心角度,还可加入两块垫片,将滚动中心升高最多2mm
  CNC-machined from premium lightweight Swiss 7075 T6 aluminium, hardcoated for extra durability and long life, it offers new and unique possibility to adjust the roll-center in 1:8 off road cars. The upright has 3 holes where the upper linkage can be mounted by aluminum ball with thread, while aluminium shims can be used for increasing or decreasing angle of roll center. Smart Xray engineering includes the use of composite bushings to secure ball-bearings in both sides of the hub carrier, allowing perfect fitment and smooth operation to ultimately impart much higher lifespan compared to bearings installed directly into aluminium hub carriers. Additional roll center adjustments are possible through the use of composite roll center bushings which can be inserted in two different orientation positions for the pivot pin. Holes in the upper position give +2mm upper roll center, while holes in the lower position are equal to the standard composite roll center position.
Source: Xray [teamxray.com] & redrc.net
