Losi 1/10 XXX-SCB short course buggy
11-3-11 14:18| 发布者: admin| 查看: 4733| 评论: 5
Losi推出1/10 XXX-SCB短卡Buggy型遥控车,使用XXX-platform车架开发而成,RTR,装备 Spektrum 2.4GHz遥控设备, 2S 锂电,铝制油压避震器,相信这是一款充满乐趣的产品!
Features
- Detailed driver figure and cockpit
- Aluminum, adjustable oil-filled, coil-over shocks
- LiPo-compatible ESC
- LM-32K performance motor
- Spektrum SR300 receiver with 2.4GHz DSM technology
- 3-gear transmission with sealable differential
- Adjustable slipper clutch
- Digital steering servo
- Durable, composite-molded XXX-chassis
- Losi exclusive Eclipse SCT treads on XXX-SCT Wheels
- Off-road beadlock-style wheels as used on the XXX-SCT
- 3-piece Lexan full-scale inspired desert buggy body
- Realistic off-road bumpers and roll cage
- Captured hinge pins
Product Specifications
Type: Short Course Buggy
Scale: 1/10
Length: 20.078 in (510mm)
Width: 11.42 in (290mm)
Height: 7.24 in (184mm)
Wheelbase: 12.95 in (329mm)
Weight: 4.25 lb (1.92 kg)
Motor or Engine: Losi LM-32K performance motor
Speed Control: LiPo-compatible ESC
Radio: Spektrum 2.4GHz DSM Losi radio system
Shock Type: Coil-over, oil-filled
Ball Bearings: Complete
Source: Losi [losi.com] & Redrc.net
    引用 fmatrix 11-3-15 17:40
    看到时悬挂如何了,1:1的悬挂是比较高的,保证通过性。就怕1:10也是这样高的话,那过弯就会翻车了,如果调低悬挂的话,通过性又是个问题。
    引用 nso221100 11-3-12 18:21
    4K以内的话 我就能买得 ...
    引用 邦德座驾 11-3-12 15:53
    比较像真实的baja,有感觉。
    引用 悠久之翼 11-3-12 08:06
    帅,价格应该至少要3K以上,LOSI的车都不便宜
    引用 怪同学 11-3-11 17:37
    沙发~样子很帅~不知价格几何?小朋友什么都不懂~请各位高手多多指教~感谢各位阅读~
    查看全部评论(5)
