Losi 1/24-scale RTR Micro 4×4 Trail Trekker
11-2-18 23:55| 发布者: admin| 查看: 8333| 评论: 8
Team Losi推出一款小比例的穿越遥控车,1/24 RTR四驱电动遥控车,有着类似攀爬车的车架结果,遥控设备使用Spektrum 2.4GHZ DSM技术,4.8v 220mAh 镍氢电池,相信这款产品是充满乐趣的遥控车,尤其适合室内、花园的地形行走。
Features
- Front and rear solid axles with worm gear drive
- Powerful micro motor with plenty of scale power
- Losi radio system with Spektrum 2.4GHz DSM technology
- 4-link suspension articulation
- Full-time 4WD with front and rear locked differentials
- 2-in-1 receiver/ESC combo unit
- Micro steering servo
- TVP (twin vertical plate) chassis
- Scale, all-terrain treaded tyre
- Chrome, scale off-road wheels
- Realistic front and rear bumpers
- 4.8V 220mAh NiMH battery and charger included
- Avaliable in Black and Red or Silver and Red
Specification
Length: 175mm (6.89 in)
Width: 85mm (3.35 in)
Wheelbase: 122mm (4.8 in)
Weight: 229.63 g (8.1 oz)
Height: 105mm (4.13 in)
Radio System: Pistol-style Spektrum 2.4GHz DSM Technology
Shock Type: Coil-over, friction dampers
Ball Bearings: Complete
    引用 palemoon 11-2-22 14:44
    还是我自己用24爬改的仿真好看一些,哈哈。这个就不入了...
    引用 veyron7460 11-2-21 16:29
    太丑,就是24爬加了个大梁,没意思
    引用 dqcl101 11-2-21 14:11
    这个上市没 ?
    引用 galaxy3000 11-2-20 22:08
    220mAh?呵呵,玩的时候,可要记得多带几块备用哦。
    引用 znn331 11-2-20 21:10
    moonwaker: 看了视频, 这是爬爬来的
    视频哪里又看?
    引用 moonwaker 11-2-19 21:02
    看了视频, 这是爬爬来的
    引用 znn331 11-2-19 00:33
    还有 4.8v 220mAh 镍氢电池 可以行走多久呢???
    好好玩 适合我 多少米!!
    查看全部评论(8)
