Sanwa HVS-ZV 和 HVS-ZS 舵机
10-3-29 08:54| 发布者: admin| 查看: 2790| 评论: 0
sanwahvs2Sanwa推出两款新舵机, HVS-ZV 和 HVS-ZS,ZV为24.2KG/cm/40度/0.08秒,而ZS为20.5KG/cm/0.07秒,两款都是大扭力高性能舵机,高质量日本轴承,耐用性极高。详细介绍在本文内。Features
  • Double isolation against humidity
  • Motor lifetime 200.000 cycles
  • High-quality Japanese ball bearings
  • Reliability test at highest temperatures, lowest temperatures, extreme humidity, and continuous operation.
  • Shock proven
  • Servo case made from special high-quality plastic
  • Race proven by world champions
Specifications
  • Speed 6.0V 0.08sec/40°
  • Torque 6.0V 16.2kg/cm
  • Speed 7.4V 0.067sec/40°
  • Torque 7.4V 20.5kg/cm Sanwa have released 2 new servos, the HVS-ZV and HVS-ZS. These extremely strong and fast servos are optimised for both 6.0V and 7.4V and is therefore ideal for use with nitro models, where normally a voltage regulator is mandatory. Double isolated to protect against humidity, and ball raced, the ZV can manage 24.2kg per cm and can complete 40 degrees in 0.08s. while the ZS does 20.5kg per cm and the same range in 0.07s, at 6 volts.
Features
  • Shock proven
Specifications
Source: LRP [lrp.cc]
