本帖最后由 Tuan 于 17-7-21 20:48 编辑 ARRMA BIG ROCK车壳 SHOCK ROD END SET HD (1 PAIR) FRONT & REAR BODY MOUNT SET BODY POST SET FRONT & REAR BODY MOUNT SET MIDDLE ROLL HOOP SET REAR SPOILER TURNBUCKLE M3X71MM (2PCS) GRANITE 1/10 2WD 大脚车 FRONT SHOCK TOWER SET TRUCK SUSPENSION ARM SET ROD END SET HD 57T SPUR GEAR (0.8MOD/32DP) GRANITE BODY MOUNT FRONT UPRIGHT SET 0.8M COMPOSITE GEAR SET 48P METAL GEAR SET STEERING POSTS AND SERVO SAVER SPRING SET rcfans限量hbl-666舵机 Arrma KRATON 1/8 4WD竞速卡 (红色) GEARBOX CASE SET (1PC) COMPOSITE FRONT STEERING BLOCK (2PCS) FRONT LOWER SUSPENSION ARMS L (1PAIR) SHOCK SHAFT 3.5X75MM (2PCS) REAR HUB (2PCS) COMPOSITE FRONT STEERING BLOCK (2PCS) DIFF GEAR SET (1 UNIT) SPUR GEAR 50T (1PC) REAR LOWER SUSPENSION ARMS (1 PAIR) DIRT GUARD SET FRONT UPPER SUSPENSION ARMS (1 PAIR) FRONT LOWER SUSPENSION ARMS (1 PAIR) WHEELIE BAR SET DIFF CASE ALLOY (1PC) SPUR GEAR MOD1 46T (1PC) SHOCK CAP SET (1 PAIR) REAR UPPER SUSPENSION ARMS (1 PAIR) BIG ROCK 1/8无刷大脚 有锁版(黑色) STEERING SKIDPLATE SET SLIPPER CLUTCH SPRING & PLATES SHOCK SHAFT 4X63MM (2PCS) FRONT BUMPER SET REAR BUMPER SET SLIDER DRIVESHAFT 53MM (GUN METAL) (1PC) SLIDER DRIVESHAFT 41MM (GUN METAL) (1PC) COMPOSITE CHASSIS & BATTERY DOOR- SWB SHOCK SPRING: 75MM (317GF/MM) (2PCS) SLIDER DRIVESHAFT 80MM (GUN METAL) (2PCS) DOG BONE (80MM) (2PCS) BATTERY BOX FOAM SPACER SET SHOCK SPRING: 65MM (503GF/MM) (2PCS) DRIVESHAFT END LOCKING PIN (2PCS) LEFT BATTERY BOX DRIVESHAFT BOOTS (4PCS) BALL JOINT SET BATTERY DOOR AND RELEASE SET (1 PAIR) WHEELIE BAR SET arrma outcast 6s blx ARRMA RAIDER BLS(红色) SENTON 1/10 4WD SC (盛唐) REAR HUB SC (2pcs) COMPOSITE SHOCK PART SET (2PCS) FRONT LOWER SUSPENSION ARMS S (1PAIR) HINGE PIN FRONT UPPER M4X46MM (2PCS) DIFF CASE SET (1PC) REAR LOWER SUSPENSION ARMS S (1PAIR) COMPOSITE STEERING BELLCRANK SET HINGE PIN OUTER 4X45MM (2PCS) HINGE PIN LOWER 4X67.5MM (2PCS) COMPOSITE SUSPENSION MOUNT SET (4PCS) #AR330379 SENTON 6S BODY ACCESSORY PACK COMPOSITE BODY MOUNT SET COMPOSITE BALL CUPS ALUMINIUM LOWER PLATE (Silver) (1pc) ARRMA VORTEKS BLS 有ARRMA配件需求的用户请联系客服 |
