RCMart 超级 Fans 发消息
发表于 16-3-1 09:36:30 |显示全部楼层
Hacktronic-D 1/10 有感无刷 ESC 10.5T XTA Hackmoto 电机组合
Feature:
For: 1/10
Support Brushless Sensored Motor
Multi Protection System (Motor Lock, Overheat, Signal Fail)
Comes With 25mm Cooling Fan
User Friendly Setting Interface
Can Swap Around to Crawler and TouringProgram with Firmware Update USB Cable #HTN-303
Specially for Drifters with 9 Drifting Settings (Timing Start, Timing, Timming Interval, Punch, Drag Brake, Initial Brake, Brake LV, Release Curve and RPM Lock)
Specification:
Length: 39mm
Width: 31mm
Height: 22.5mm
Forward/Brake/Reverse:Yes
Weight: 45g
Voltage Input: 4.8 – 9.9V DC, 3 – 6 Cells NiCD/NiMH 1~2-Cell LiPO / 1-3 Cell LiFe
Peak Current: 540A
Motor Limit: Over 5.5 Turns
B.E.C: 6V / 3.0A
Include:
Hactronic ESC (1 pc)
Cooling Fan (1 pc)
Power Capacitor (1 pc)
Manual
Yeah Racing Hackmoto XTA 10.5T 540 4450KV Brushless Sensored Motor #XTA-T105
Description:
Hackmoto XTA motor is the second Gen Hackmoto Motors with lots of improvements in terms of design, engineering and material and is exquisitely crafted to achieve high performance in demanding environments. The result speaks for itself and was very competitive to even the most high-end motors in the market with its low friction, low heat, low power consumption, low wearing with high power output characteristic.
The new Motor is equipped with the Xtreme Timing Advancement System (XTA™ ) for precise timing and turbo timing as well as physical timing set ups when used with Hacktronic ESC.
Feature:
For: 1/10 RC Car
Material: Aluminum
Color: Gunmetal
XTA™ Timing (-3 to +3 Step-less adjustment)
Premium Quality Ball Bearing Minimum Friction
High Purity Copper Winding
Removable/Replaceable Rotor
High Power Neodymium Magnet
Premium Quality Material for Minimum Heat and Energy Loss
Sensor-based for Excellent Torque and Low-Speed Smoothness
Sensor-based for Precise Timing and Turbo Timing function for exceptional Acceleration and Top Speed. (With Hacktronic ESC)
Aluminum Endbells For Light Weight and better heat dissipation
Venting Holes Engineered Carefully For Efficient Air Flow and Cooling
Specification:
Turns: 10.5T
Watts: 245
KV: 4450
LiPo: 1-2S Lipo
Weight: 160g
如果您想了解更多关于我们品牌的资讯,
请咨询电波模型淘宝店旺旺客服:
[url]http://rcmart.taobao.com
或联系QQ2713236907
