发表于 13-11-11 16:38:14 |显示全部楼层 来自: 中国广东广州
Battery Type: 锂聚合物电池组(LIPO) 香蕉插型
Capacity: 6300mAh
Configuration: 7.4V
Dimensions: 厚25mm x宽46mm x 长138mm
Plug Type:T插(可按客户需求配)
Weight: 285g
Charge Rate: 2A
Continuous Discharge: 30C (189A)
Min Discharge Volts Per Pack: 6.0V
Max Volts Per Cell: 3.0V建议设置截止电压3.3V
Max Volts Per Pack: 8.4V
Capacity: 5300mAh
Configuration: 7.4V
Weight: 285g
Charge Rate: 2A
Continuous Discharge: 40C (212A)
Capacity: 5000mAh
Configuration: 7.4V
Weight: 285g
Charge Rate: 2A
Continuous Discharge: 50C (250A)
欢迎进入官方旗舰店
