council 长老 Fans 发消息
发表于 06-5-23 01:01:53 |显示全部楼层 来自: 英国
Competition Radio Control Car and Buggy
AXE Rossi 21 COBRA Model 198R21 Off-Road 1/8-Scale Buggy Competition Engine with instructions, accessories and a glow plug. Rossi engines come with 3 year warranty for any manufacturing defect.
The AXE Motor Rossi Cobra engine specs are:
Displacement: 3.5cc
Horse Power: 3.1 HP
RPM: 40800
Bore: 16.00 mm
Stroke: 17.40 mm
Ports: 7 / 2 Buster Exhaust System
Crankshaft & Type: 14 SG
Glow Plug: Standard
Weight: 340 gr
features of this engine are:
crankshaft with with tungsten inserts on the flywheel for balanced performance.
New carburetor with heat insulation prevents fuel vaporization.
New shell mold casting crankcase with a new patented intake ports system.
Buster exhaust system.
Bigger rear ball bearing.
Rossi engines are hand made in Italy, built to the most precise tolerances, with the finest Swiss CNC machine equipment, using the best quality materials to give you the highest performance and longest life.
克克 终极 Fans 发消息
发表于 06-5-29 08:43:55 |显示全部楼层 来自: 中国上海
回复 #1 council 的帖子
怎么图片中写Rossi Engines USA?不是说rossi 是意大利生产的吗?
发表于 06-5-29 08:51:51 |显示全部楼层 来自: 英国
图中是使用US代理的照片
