#108928 Alu Adj. Shim for 1/10 Off-Road Alu Set-Up - XRAY XB4 (2) Aluminum shim for 1/10 off-road rear wheel axle For 1/10 off-road HUDY set-up system Must be used with XRAY XB4 Set-up system leans against the shim Aluminum shim fits on the rear wheel axle, and the set-up system leans against the shim. For use with XRAY XB4 or any off-road car on which the set-up system cannot be inserted on the non-threaded part. The set-up system will then sit properly on the threaded area of rear wheel axles only. Set of 2. |
