XB4 Anti-Roll Bars
查看: 1831|回复: 0| [复制链接]
发表于 13-3-11 12:58:47 |显示全部楼层
XB4 Anti-Roll Bars
optional anti-roll bars
available in different thickness for fine-tuning
premium heat-treated spring steel wire
laser engraved size
manually measured, selected and straightened
Optional spring steel anti-roll bars for XB4. This optional anti-roll bars offer different anti-roll stiffness adjustment so that you can fine-tune the set-up of your chassis with maximum finesse. For easy recognition the anti-roll bars have laser-engraved stripes (to indicate bar thickness) for easy and instant recognition. Black color.
Both front and rear anti-roll bars are interchangeable as they have same design and shape.
#362470 Anti-Roll Bar 1.0mm
#362471 Anti-Roll Bar 1.1mm
#362473 Anti-Roll Bar 1.3mm
#362474 Anti-Roll Bar 1.4mm
#362476 Anti-Roll Bar 1.6mm
#362478 Anti-Roll Bar 1.8mm
http://www.world-model.com/newproduct/362470.html
