#334131 Glued Brake Pad Set - Ultra-Efficient (2)
Factory pre-assembled brake pad set Consistent and precise braking High-precision, ultra-efficient CNC-machined steel brake pads Precision ground for ultra-smooth surface finish Maximum braking efficiency Heat-treated for maximum lifespan Special high-grip brake pad material is specially bonded to backing plates Factory pre-assembled brake pad set for consistent and precise braking. High-precision, ultra-efficient steel brake pads are CNC-machined and precision ground on both sides for an ultra-smooth surface finish to guarantee maximum braking efficiency. Brake pad backing plates are heat-treated for maximum lifespan. Special high-grip brake pad material is specially bonded to backing plates for high resistance to generated heat build-up. Set of 2. |
