编程翻译(一)
查看: 2021|回复: 0| [复制链接]
爆走控控 终极 Fans 发消息
发表于 12-6-29 16:11:16 |显示全部楼层
read through all of the programming steps before you begin
阅读所有的编程步骤开始之前
rif you get lost during programming or receive unexpected results
如果你迷失在编程或收到意想不到的效果
simply unplug the battery
只需拔下电池
wait a few seconds
等几秒钟
plug the battery back in
塞电池回来
and start over
重新开始
make sure the LED on the VXL-3S is on and red
确保vxl-3s的LED是红色的
press and hold the EZ-set button for ten seconds ,the LED will turn off and then light green  ,also a "rising"musical tone will be emitted from the motor
按住ez-set按钮十秒,发光二极管会关闭,淡绿色,也是一个“上升”的音乐基调会发出电机
low-voltage detection is now ACTIVATED
低压检测现在激活
transmitter adjustments for the VXL-3S ESC
发射器调整为vxl-3s调速器
before attempting to program your VXL-3S ESC,it is important to make sure that your transmitter is properly adjusted (set back to the factory defaults),otherwise,you may not get the best performance from your speed control
在试图计划vxl-3s调速器,它是重要的是要确保你的发射机是适当的调整(恢复到出厂默认设置).否则,你可能不会获得最佳性能的速度控制.
the transmitter should be adjusted as follows
发射器应作如下调整
if the transmitter setting have been adjusted ,reset them to the factory defaults,
如果发射器设置进行了调整,重置到出厂默认值
1.turn transmitter off
将发射机关机
2.hold both MENU and SET
同时按住MENU和SET键
3.turn transmitter on
将发射机打开
4.release MENU and SET ,the transmitter LED will blink red
释放菜单设置,发射发光二极管闪烁红色
5.press SET to clear settings,the LED will turn solid green and the transmitter in restored to default
按SET明确的设置,发光二极管会变成绿色常亮,发射器的恢复默认值
1.connect a fully charged battery pack to the VXL-3S
连接一个完全充电电池的vxl-3s
2.turn the transmitter(with the throttle at neutral)
把发射机(用节流阀在中性)
3.press and hold the EZ-set button(A),the LED will first turn green and then red,release the EZ-set button
按住ez-set按钮(A),发光二极管会把绿色和红色,释放ez-set按钮
4.then the LED blinks RED ONCE ,pull the throttle trigger to the full throttle position and it there (B)
然后闪烁红色,拉油门触发的全油门位置和它(B)
5.then the LED blinks RED TWICE, push the throttle trigger to the full reverse and it there (C)
然后闪烁红色的两倍,推油门触发的逆向和(三)有
6.then the LED blinks GREEN TWICE,programming is complete ,thr LED will then shine green or red (depending on low-voltage detection setting)indicating the VXL -3s is on and at neutral(D)
然后闪烁绿色两次,编程完成,术将照耀绿色或红色(根据低压检测设置)表明VXI -是与在中性d
