纽伦堡09展览 RB 产品
查看: 7585|回复: 16| [复制链接]
邱志鴻 初级 Fans 发消息
发表于 09-2-7 09:23:45 |显示全部楼层 来自: 中国广东深圳
阿逼...好牛B的引擎啊
kbl 超级元老 发消息
发表于 09-2-7 19:13:44 |显示全部楼层 来自: 中国天津
:em07:
council 长老 Fans 发消息
发表于 09-2-9 14:17:25 |显示全部楼层 来自: 中国广东广州
RB的新发动机系列,其中Buggy引擎的重量将减轻17%(相对以前的产品)!!!
council 长老 Fans 发消息
发表于 09-2-9 14:20:17 |显示全部楼层 来自: 中国广东广州
平路用引擎 C9 , 9-port line, 14.5mm 曲轴,首次使用 L2G 散热顶
Their flagship .12 motor, the T9RC comes with the new cooling head which helps reduce the engine temperature by 20 degrees and is also supplied on the non RC (hand modified) T9. Also in the .12 series is the new TJ9 entry level engine.
Selected as being the most suited for the resurgent 1/8th scale 2wd pan car class, the Classico9 is a 7 port engine with a 14mm crankshaft and smoothly delivers the power, something very necessary for this type of car.
Leaving engines behind, RB have a new formula fuel, which is now also supplied in a new drum, and that helps the engines perform better while being non agressive to the parts. Also in the same cabinet were cans of Exhaust protect, that is a teflon spray that when applied to a brand new, or already clean exhaust system, enables it to be easily cleaned following running as the dirt fails the stick to it.
Other new items include the limited edition pit box, that is supplied with a RB skin which will only be availble for the first 100 owners. There is a new design for the pit bag, an orange anodised exhaust gas cooler, a new range of clutch tools and coming in mid April is a new range of tools.
council 长老 Fans 发消息
发表于 09-2-9 14:20:32 |显示全部楼层 来自: 中国广东广州
羅紹岐 超级元老 发消息
发表于 09-2-10 12:03:25 |显示全部楼层 来自: 中国广东深圳
啥時候能有顆RB多好~!~~
