New Corally RDX
查看: 2333|回复: 2| [复制链接]
发表于 04-8-6 00:47:00 |显示全部楼层 来自: 英国
After a long and extensive R&D period Corally is proud to introduce the all new RDX. Top drivers Sakke and Simo Ahoniemi have first showed its performance by making top 10 positions at the recent 2004 European Championships. Chris Tosolini will race the RDX in the US. The release is planned for September 2004.
The all new features include:
- Ultra low centre of gravity
- Super narrow 3mm chassis with semi cut motor position for maximum stiffness
- Chassis mounted steering levers
- Lower roll centre adjustment possibility
- 2-Belt drive system with aluminium pulleys and spur gear adapter
- Lightweight rear differential
- Lightweight front 1-way with hardened aluminium outdrives
- Double supported layshaft between both bulkheads
- Composite reinforced short wishbones
- Motormount integrated with rear left bulkhead
- Rear shocks positioned in front of the wishbones for even better weight balance
- Wheel base extended by 7mm
- Identical font and rear shock towers
irvine 超级元老 发消息
发表于 04-8-6 01:13:00 |显示全部楼层 来自: 中国广东广州
低重心设计哦!
车神 终极 Fans 发消息
发表于 04-8-9 02:51:00 |显示全部楼层 来自: 中国广东广州
玩漂移~?
