Losi 推出Micro-Baja. 以Micro-T为蓝本, 原车用 NiMH 电池,独立悬挂,27MHz Losi AM 遥控,一辆娱乐的小小车
Features
- Fully independent suspension with friction dampers
- Differential-equipped transmission with adjustable slipper clutch
- Powerful, preinstalled micro motor
- Included NiMH battery pack with portable alkaline automatic peak charger
- Losi 27MHz AM radio system
- Electronic Speed Control with Reverse
- Micro narrow ribbed tires (front), micro step pins (rear) mounted on chrome dish wheels
- Includes 8 AA heavy-duty batteries for transmitter
- Includes 8 AA alkaline batteries for charger
Product Specifications- Type:2WD Baja Bug RTR
- Scale:1/36
- Length:4.5 in (114mm)
- Width:3.5 in (89mm)
- Wheelbase:3 in (76mm)
- Weight:3.4 oz (96 g)
- Chassis:Composite tub
- Suspension:Independent
- Drive Train:3-Gear transmission with gear diff and slipper
- Tire Type:Micro narrow ribbed (front), micro step pins (rear)
- Motor or Engine:Micro electric
- Speed Control:Electronic, fully proportional FWD/REV
- Radioosi 27MHz AM pistol
- Servos:Sub-micro
- Batteries:4.8V 150mAh NiMH (included)
- Chargereak (included)
- Wheel Size:0.75 in (19mm) diameter
- Kit/RTR:Complete RTR
- Shock Type:Coil-over friction dampers
- Body:Factory-decorated Baja bug
- Ball Bearings:BB- Equipped transmission
