Some TRF415 MSXX Marc Rheinard Edition 2007 Specs: Lower Deck - 2mm carbon fiber (same as MSXX) Upper Deck - 2.5mm carbon fiber (new design) Damper Stay - 3mm (same as MSX) Damper Support - Carbon fiber (same as MSXX) Rear Upper Brace - Separate type (new design) Front Unit - Direct drive Center Pulley - 16T Rear Unit - Direct drive Diff Pulley - 36T Suspension Arm - Reversible suspension Dampers - TRF dampers (new design) Suspension Pin - Titanium-coated Screws - Steel Air Scoop - Included Wheel Axles - Steel Bumper - (same as TB Evo 5) Stickers - (new design) |
