田宫M08即将公布
查看: 8100|回复: 22| [复制链接]
Vango 论坛元老 发消息
发表于 19-3-21 21:03:18 |显示全部楼层 来自: 中国香港
silversol 发表于 19-3-20 14:40
怎么没后续了
M07 R已经出货了,现在都在等着田宫的官推出M08的图……
Garphy 论坛元老 发消息
发表于 19-3-28 10:04:34 |显示全部楼层 来自: 中国北京
参数出来了!图依然没有。果然被众多模友说中了。
后驱、轴距沿用210/225/239,兼容M06车壳
前后分块布局,舵机靠近前轴、动力及电池后置;
部分零件沿袭M07
Tamiya RC 58669 M08 Chassis kit
This TAMIYA high-performance rear-wheel drive R/C chassis assembly kit is constructed around a rigid monocoque with the main frame split into front and rear sections. It offers superior rear high traction drive characteristics and fuss-free maintenance of parts such as the easy-access differential. C.V.A. (Constant Volume Adjustable) oil shock-damped 4-wheel double wishbone suspension features dedicated long arms and steering linkage components for a range of setup options. A silky-smooth drivetrain utilizes full ball bearings, oil-filled gear differential unit and universal drive shafts. It can be assembled with a 210mm (S), 225mm (M) or 239mm (L) wheelbase, making it compatible with appropriately-sized existing Tamiya M-chassis body parts sets.
•        1/10 scale R/C model assembly kit.
•        The chassis is split into front (suspension and servo) and rear (motor and battery) sections. It can be assembled into three different wheelbases: S (210mm), M (225mm) or L (239mm).
•        Rear-midship motor powers rear wheels via a differential in the Mid-Rear setup.
•        Oil-filled differential gear used from the M-07.
•        Features proven M-07 Concept designs: suspension arms, uprights, suspension mounts and aluminum parts.
•        Includes CVA oil dampers, universal drive shafts, full ball bearings and hi-torque servo saver.
•        Comes with new front suspension mounts (0 degrees) and hub carriers (2 degrees) for a total caster angle of 2 degrees.
•        Compatible with M-06 Chassis bodies.
•        Requires: 2-Channel Radio, servo, ESC, motor, 7.2-7.4volt battery pack & compatible charger, and body set.
•        Compatible with M-07 Concept Hop-Up Option parts such as Aluminum Rear Suspension Mount (Skid Angle Adjustment) (54787), Aluminum Rear Uprights (54781) and Low-Friction King Pin Pipes (54813).
Vango  原来你已经发了…… 还好我发的是中文版,有些许Contribution……  详情 回复 发表于 19-3-28 10:32
Vango 论坛元老 发消息
发表于 19-3-28 10:32:52 |显示全部楼层 来自: 中国香港
前后分块布局 ...
原来你已经发了……
