kingmax推出新产品BLS13015,这是一款无刷全钢齿防水超大扭矩的大舵机,可支持7.4-12.0V工作电压,堵转扭矩130kg,空载速度0.15S,适合大比例遥控车(1/5车型)、大型固定翼以及工业使用。已经上市在售。 基本参数: Dead band: 4μsWorking frequence: 1520μs / 330hz Operating Voltage: DC7.4~12 V Operating Speed (7.4V): 0.257sec/60 degrees Operating Speed (8.4V): 0.22sec/60 degrees Operating Speed (12.0V): 0.15sec/60 degrees Stall Torque (7.4V): 88.0kg.cm (1222.32oz/in) Stall Torque (8.4V): 98.0kg.cm (1361.22oz/in) Stall Torque (12.0V): 130.0kg.cm (1805.70oz/in) Dimensions: 65.8X30X58.5mm /2.56X1.17X2.28in Weight:248g (8.74oz) Connector Wire Length: 300mm (11.70in) 详情可以进店咨询Kingmax工厂店 https://shop62397508.taobao.com |
