T-Work's 离合器罩杯专用轴承5*10*4mm (尼龙支撑架)(10個) New from T-Work's Racing the custom made 5x10x4 Hyspin Bearing specifically designed for 1/8th GP Buggy Clutch Bells. The feature that sets this bearing apart is the custom designed Nylon Retainer which holds the Stainless Steel Balls in place within the bearing infrustructure, a feature normally found in larger engine bearings. The benefit of a Nylon Retainer is its ability to handle higher operating temperatures and RPMs making them much more reliable than bearings fitted with steel retainer, only Hyspin Bearings of ABEC5 grading or better will leave the factory and will feature rubber seal on one side and a steel shield on the other for higher rpm and easier cleaning. 數量:1包10個 |
