the Hellfire SS!
查看: 3517|回复: 11| [复制链接]
council 长老 Fans 发消息
发表于 06-5-25 12:28:42 |显示全部楼层 来自: 英国
council 长老 Fans 发消息
发表于 06-5-25 12:29:42 |显示全部楼层 来自: 英国
council 长老 Fans 发消息
发表于 06-5-25 12:30:09 |显示全部楼层 来自: 英国
council 长老 Fans 发消息
发表于 06-5-25 12:30:52 |显示全部楼层 来自: 英国
council 长老 Fans 发消息
发表于 06-5-25 12:31:17 |显示全部楼层 来自: 英国
council 长老 Fans 发消息
发表于 06-5-25 12:31:41 |显示全部楼层 来自: 英国
council 长老 Fans 发消息
发表于 06-5-25 12:32:01 |显示全部楼层 来自: 英国
Features
Pre-guled Nubz tyres
Off-road Molded Wing, Black
Self-lubricating molybdenum rod end set.
52T Lightweight Spur Gear
Optional front lower suspension mount (+2 to -2 degrees)
Machined purple, anodized, aluminium shock cap
TiN suspension shafts
7075 machined aluminium front and rear braces
Finned, machined aluminium, purple anodized engine mounts.
Machined 5mm hard anodized aluminium shock towers (7075 alloy)
Fine adjustment range in camber link holes
Machined delrin shock pistons
Knurled M17 nut for monster truck and buggy hex adapters.
Machined 3mm lightweight aluminium hard anodized 7075 alloy chassis
7075 machined aluminium steering plate with extra machining to reduce weight and add tie rod clearance
7.5mm thick rear hex adapters. adds steering without loosing rear end grip.
Fiberglass brake pad
ybm3dm 超级元老 发消息
发表于 06-5-25 12:56:05 |显示全部楼层 来自: 中国上海
好车!!!比RTR更精致!!有很多XB8的影子
nigo 论坛元老 发消息
发表于 06-5-25 15:39:00 |显示全部楼层 来自: 中国天津
好看啊
发表于 06-5-25 18:52:36 |显示全部楼层 来自: 中国云南昆明
