下面是官方介绍∶ Features: Optional “dye-able” tube chassis included. Optional sway bar set included. Optional rear aluminum link plates included. Optional single speed or 2-speed transmission included. Optional differential spool included. Solid axles front and rear with metal diff covers. Full Time 4WD with limited slipping center differential using high strength metal gears. One million weight differential oil. Shocks provide long 30mm (Front) and 43mm (Rear) of travel. Strong triangulated 4-link suspension on the front and 4-link with trailing arms on the rear. Universal axle joints used to provide maximum strength. Officially licensed molded 2.2 Black Raceline Monster wheels. Oversized differential and transmission gears. |
