注册 登录
RCFans|遥控迷 返回首页
Demon3C的个人空间 https://rcfans.com/?115633 [收藏] [复制] [分享] [RSS]
日志
电车相关知识
已有 2021 次阅读11-9-8 17:16
电车RC相关知识小汇总 ^_^
所有链接均需要复制到浏览器地址栏中打开,直接点击不能访问:
***以下内容为YST本人辛苦搜集整理所得,旨在方便各位玩车朋友,欢迎玩家转载,鄙视商家抄袭^_^
1新手买什么车之类的投资问题:
http://www.rcfans.com/bbs/forum.php?mod=viewthread&tid=128151
2新手入门以及漂移车的基础问题:
http://www.rcfans.com/bbs/forum.php?mod=viewthread&tid=112645
3有刷马达相关问题:
http://www.rcfans.com/bbs/forum.php?mod=viewthread&tid=134519
4无刷马达/套装相关问题:
http://www.rcfans.com/bbs/forum.php?mod=viewthread&tid=152779
5新手更换无刷的相关问题:
http://www.rcfans.com/bbs/forum.php?mod=viewthread&tid=126032
6有感与无感较为深入的认识:
http://www.rcfans.com/bbs/forum.php?mod=viewthread&tid=156167
7齿比计算以及推荐齿比:
http://www.rcfans.com/bbs/forum.php?mod=viewthread&tid=168431
8马达齿T数和P数的问题:
http://www.rcfans.com/bbs/forum.php?mod=viewthread&tid=161556
9再说齿轮的P(模数):
http://www.rcfans.com/bbs/forum.php?mod=viewthread&tid=171818
10电池/充电器相关问题:
http://www.rcfans.com/bbs/forum.php?mod=viewthread&tid=119773
11锂聚合物电池(LIPO)的选择、使用、保养、问题解决常识:
http://www.rcfans.com/bbs/forum.php?mod=viewthread&tid=214255
12B6以及一般万能充电器的使用说明:
http://www.rcfans.com/bbs/forum.php?mod=viewthread&tid=121663
13  2PL遥控器改三通道问题:
http://www.rcfans.com/bbs/forum.php?mod=viewthread&tid=132044
14遥控器中的AM/FM/2.4G问题:
http://www.rcfans.com/bbs/forum.php?mod=viewthread&tid=101296
15各类遥控中文说明书:
http://bbs.rcfans.com/forumdisplay.php?fid=13&filter=digest
16如何喷车壳:
http://www.rcfans.com/bbs/forum.php?mod=viewthread&tid=13725
17头单尾直是什么:
http://www.rcfans.com/bbs/forum.php?mod=viewthread&tid=122248
TAMIYA相关问题
1PS喷漆以及色板:
官网色板:
http://www.tamiya.com/english/products/list/polycarbonate_spray/kit86001.htm
中文对照:
http://www.rcfans.com/bbs/forum.php?mod=viewthread&tid=15037
2田宫主流车架说明书/设定表下载地址:
http://www.tamiya.com/japan/download/rc_index.htm
3田宫1/10房车列表:
http://www.tamiya.com/japan/rc/rcitem/kit/kit580T01.htm
4TAMIYA美国网站帮助中心:
http://www.tamiyausa.com/product/rcpss.php
5TAMIYA美国网站RC产品总目录:
http://www.tamiyausa.com/product/category.php?main-id=30|70
6TT01/TB02/TA05的对比问题:
http://www.rcfans.com/bbs/forum.php?mod=viewthread&tid=124521
其他RC小知识
1车壳问题
一般电房的车壳的宽度都是190MM的,而油房则主要是200MM。但是部分漂移电车,为了设定需要,使用加宽OFFSET的轮毂,或者加厚的结合器,达到200MM的宽度,也需要使用200MM的车壳 。特殊电车例如HL的电房,也是200MM。
http://www.rcfans.com/bbs/forum.php?mod=viewthread&tid=167152
2轮毂问题
房车的轮毂基本是通用的,轮毂外径52MM,结合器直径12MM,结合器厚度由3~5MM不等,轮毂宽度则主要只有24MM和26MM两种。结合器深度较深的轮毂,需要使用较厚的结合器,否则容易卡死轮毂无法转动。
而胎皮的外径则为63MM,内径52MM,宽度也分为24MM和26MM两种,要注意配套使用^_^
3关于OFFSET
OFFSET是指轮毂的结合器与轮框之间的偏移量。例如+3MM OFFSET的话就是轮毂比0MM的往外凸3MM,两边同时装上之后就是比原装0MM多出6MM,用于配合不同的车壳使用。如果搭配不当,则会出现轮毂比车壳宽而往外凸,或者轮毂比车壳窄而往内凹。请根据车壳实际选择。
更多资讯慢慢添加中...
完全新人请访问RCFANS新手讨论区或RCFANS资讯版中的新手入门板块,谢谢!
新人应该学会使用RCFANS中的搜索功能,遇到不懂的问题,应尽量使用搜索,避免重复提问^_^
ACTIVE A210SS车架,很好的M车,呵呵^_^
http://www.rcfans.com/bbs/forum.php?mod=viewthread&tid=178900
转载至极RCFans模型店极速模型店
路过
雷人
握手
鲜花
鸡蛋
评论 (0 个评论)
