Team Muso R12 系列 World GT转换套件
13-10-22 22:24| 发布者: rcfans| 查看: 7053| 评论: 0
日本Team Muso公司推出World GT 转换套件给Yokomo R12 和 R12C3 1/12电动平路车(12仔)进行升级转换,将12仔变成一辆200mm宽度的WGT级别遥控车。套件内包括更长轴距的底板、碳纤前防撞、电池座、铝制Hub等零件,但不包括轮胎、车壳和任何电子设备。由于WGT遥控车车速高,操控灵敏,所以在日本有大批玩家。Team Muso公司还给Yokomo的GT500产品推出相应升级改装产品。
http://www.team-muso.com/r12c3/new_DSC_0084.jpg
http://www.team-muso.com/r12c3/new_DSC_0085.jpg
http://www.team-muso.com/partslist/rear-2.jpg
MUS-R12C3WGTCV R12/R12C3 WGT Conversion Kit 套件包括:
R12WGT Chassis x1,R12WGT Carbon Front Bumper x1,
R12WGT Lower Brace x1,R12WGT Front Mount Brace V2x1,
R12WGT Upper Brace x1,R12WGT Chassis Brace x1,
R12WGT Battery Support x1,R12WGT Battery posts x2,
R12WGT Front Suspension Spacer x2,R12WGT Rear Bulkhead Spacer x2,
R12WGT Right Wheel Hub x1,R12WGT Left Wheel Hub x1,
R12WGT Thrust Cone x1,R12WGT FrontShock Extension Parts x1,
3x10 Socket Head Cap Screw x8,Multi Foam Bumper For WGT x1,
Damper Tube Set x2,Turnbuckles 54mm x2
●Correspondence chassis
Yokomo R12 wide chassis(For narrow specifications,
please change to a wide specification front arm)
※ R12 C Graphite rear axle the (narrow specification)
If you are using, please use the Yokomo kit
manufactured by standard thrust cone thrust cone.
GT500
●For the conversion kit, RC equipment,body,motor,battery,
tires,and wheelsare not included.
GT500 R12 is required to complete chassis kit.
