Xray 正式推出 XB4 2014 电越
13-10-21 12:51| 发布者: rcfans| 查看: 8355| 评论: 1
新特性
– New chassis frame
– New arm design
– New SFA suspension flex adjustment
– Narrow arms with 2mm wheelbase shims
– New rear shock mounting positions
– New weight balance system
– New lightweight slipper clutch plates
– New SLS clipper clutch pads
– New stronger slipper spring
– New +1mm off-set front wheels
– Reinforced front and rear bulkheads
– Reinforced shock towers
– Reinforced outdrive adapters
– Reinforced bevel gears
– Reinforced ball joints
– Updated top deck
– Shock O-rings included
– Front shock tower protector included
http://www.teamxray.com/xb4/images/gallery-main/xb4-gallery-large-08a.jpg
http://www.teamxray.com/xb4/images/gallery/xray-xb4-06.jpg
12
    引用 roy821030 13-10-21 13:41
    看着挺酷的
