Serpent 蛇仔的1/10竞赛级方程式F1遥控车F110即将上市,全车使用碳纤和铝制零件,竞赛级产品。车架有多个可调设定部分,支持标准和短身2S锂电,支持橡胶或海绵轮胎(可调车高)。配有坚固尼龙物料尾翼和前鼻翼,支持市面上多款F1车壳安装到车架上,超强壮的舵机座和舵机保护器能有效减低碰撞后对转向舵机的损害。轻量化珠差、轻量但强化的尾轴能有效提高传动效率。Kit款式,分别提供180mm FR和RR版本(带橡胶轮胎)供玩家选择,升级200mm加长前摇臂更好支持海绵胎的版本也将上市。 点击这里->进入Serpent 蛇仔品牌专区参与互动 ![]() ![]() ![]() Features - Carbon fibre chassis plate in 2.5mm - Chassis and holders allow Shorty and Normal packs - Strong front nylon wing which fits most common lexan wings - Front trackrod suspension with lower 3mm carbon wishbones; fully adjustable - Durable spring loaded steering blocks with upper pivot ball - Adjustable ride height to suit both rubber and foam tyres - Super strong machined aluminium servo holder and strong servo saver - Large volume main central shock absorber RCCX type; threaded housing - Spring loaded Link-type rear suspension with single tube - Carbon fibre body mount, doubles as side spring holder and tube holder - Captured pivot ball connection - Pancar style rear end with a strong carbon fibre and aluminium powerpod - Strong and light aluminum rear axle - Durable and light ball-differential, and light alu hex wheel-hubs - Large durable white rear wing - High quality ball-bearings and fasteners - Strong nylon body mounts with fine tuning nuts - Kit-version will be 180mm FR and RR with rubber tyres (longer front arms will be optional to arrive at 200mm for use with foam tyres) |
