Serpent蛇仔正式推出全新811 Cobra 2.0版电动越野车。这是一台1/8四驱竞赛级电动越野车,在过去一年的新车研发过程中,811 2.0已经由车手驾驶出现在全球各大赛事,厂方在听取了众多车手的反馈意见后不断改良。2.0新版811电越转向反应有一定提升,尾部抓地力增强,传动系统使用更大尺寸轴承确保传动更坚固耐用,除此之外新车还有多处进行了升级或换用新零件,整体性能有了质的提高!本月中旬开始发货。 点击->这里进入Serpent品牌专区参与互动
![](http://image.rcfans.com/portal/201303/06/013017d0cwyk0hgw3fycyf.jpg) Main new features - new wider rear end with new geometry for more rear traction and an easier handling car with wider sweetspot - rear shockabsorbers moved to the back of the shocktower - longer rear shocks; with longer housing and shockrods for more travel - rear wing with integrated holders for the ballraced rear anti-roll bar - longer rear lower arms, new higher carbon shocktower, longer rear shock, new upright - lexan mud-guards to mount on lower rear arms - nylon mud-scrapers mount on the rear uprights - improved differential gears - as already in the Be version - larger bearings in steeringblocks and uprights 8X16X5 (2) and 15x21x4 (2), - transmission using larger bearings 8x19x6 and 13x19x4 and new couplers for extra durability
![](http://www.serpent.com/files/img/1234576914b.jpg)
![](http://www.serpent.com/files/img/1234576916b.jpg)
![](http://www.serpent.com/files/img/1234575016b.jpg)
![](http://www.serpent.com/files/img/1234574762b.jpg)
