ST Racing Slash 4×4升级转换套件
12-12-11 14:52| 发布者: rcfans| 查看: 5679| 评论: 8
ST Racing Concepts推出Slash 4X4短卡使用的LCG(低重心)升级转换套件。包括2.5mm厚度碳纤二楼板,CNC工艺4mm厚度铝制底板,铝制马达座等组件。Slash 4X4短卡可直接使用升级套件,升级后车子转向更灵活,操控反应更迅速,全面提高车子的弯道速度。使用套件后车架重量有所降低,跳跃性能得到提升。厂家报价是99美元,圣诞节前上市。
LCG conversion kit features:
    CNC Machined Hard anodized HD front bulkhead
    CNC Machined Hard anodized 4mm aluminum lower chassis.
    2.5mm Graphite Upper Deck (holes pre-drilled for stock receiver box)
    CNC Machined aluminum motor mount and motor cam (motor cam allows for maintenance on the motor without losing gear mesh)
    CNC Machined aluminum rear suspension mount (x2)
    CNC Machined aluminum battery brackets and center block
    Graphite battery hold down strap
    CNC Machined aluminum chassis posts, steering posts, and spacers
    CNC Machined aluminum front sway bar mount (x2)
    CNC Machined aluminum light weight servo mount
    All hex drive hardware included
    Designed with racing in mind for 550 motor and 2S lipo (3S compatible (certain plug type might need modifications))
    Available in Blue or Black anodizing (with hard anodized lower chassis and front bulkhead) and very limited quantity in Orange, Green, Silver and Red
http://cdn8.rccaraction.com/wp-content/gallery/st-racing-concepts-slash-4x4-lcg-low-center-of-gravity-racing-chassis-conversion-kit/weight2-small.jpg?8a12f1
http://cdn9.rccaraction.com/wp-content/gallery/st-racing-concepts-slash-4x4-lcg-low-center-of-gravity-racing-chassis-conversion-kit/weight1-small.jpg?8a12f1
http://cdn6.rccaraction.com/wp-content/gallery/st-racing-concepts-slash-4x4-lcg-low-center-of-gravity-racing-chassis-conversion-kit/under-small.jpg?8a12f1
http://cdn4.rccaraction.com/wp-content/gallery/st-racing-concepts-slash-4x4-lcg-low-center-of-gravity-racing-chassis-conversion-kit/servo-mount-small.jpg?8a12f1
http://cdn4.rccaraction.com/wp-content/gallery/st-racing-concepts-slash-4x4-lcg-low-center-of-gravity-racing-chassis-conversion-kit/battery-bracket-small.jpg?8a12f1
http://cdn7.rccaraction.com/wp-content/gallery/st-racing-concepts-slash-4x4-lcg-low-center-of-gravity-racing-chassis-conversion-kit/3s-small.jpg?8a12f1
http://cdn9.rccaraction.com/wp-content/gallery/st-racing-concepts-slash-4x4-lcg-low-center-of-gravity-racing-chassis-conversion-kit/lcg1-small.jpg?8a12f1
    引用 jy5115020 12-12-14 14:35
    车身那么低,还是短卡么?不如玩越野!
    引用 瓶装牛奶 12-12-12 13:08
    AMB直接塞在舵机下面。。
    塑胶齿轮直接外露。。担心小石头小沙子扫齿。。
    那么大一块二楼板 居然不能被利用起来。。可惜。。
    费力不讨好的套件啊。。。这个
    引用 kkfungcn 12-12-12 10:57
    花这么多钱,搞一的全面改造,不如买个别的车。
    引用 super_弟 12-12-11 23:06
    很舒服啊~~~~~~~~~~~~~~~~~~~
    引用 猪猪侠 12-12-11 20:21
    解决中轴 进灰了..................
    引用 马环宇 12-12-11 18:52
    没看到任何意义,地盘那么低,姿态没了,又跑不过竞速,玩你妹啊
    引用 250527437 12-12-11 18:14
    很丑....................
    引用 zch 12-12-11 15:59
    amb摆放很有意思
    查看全部评论(8)
