Futaba推出14SG 14通道 2.4GHz FASSTest航模遥控器。内置遥感功能、支持Futaba FASST和S-FHSS技术,128X64像素显示屏。支持多语言菜单,30组模型数据记忆,可外接SD卡扩充记忆和进行软件升级。菜单内置固定翼、 滑翔机和直升机特性设定。->点击这里进入Futaba品牌专区参与讨论
- Channels: 12 proportional, 2 switched - Compatible with FASSTest, FASST and S-FHSS protocols - FASSTest telemetry – compatible with Futaba telemetry sensors (sold separately) - Free user-updatable software - 30-model memory - 10-character user naming - 10-character model naming - Airplane, helicopter and glider programming - Large, 1.75” x 3” backlit LCD screen with 128 x 64 resolution - SensorTouch programming - SD Card compatibility for external model memory and software updates (SD: 32MB-2GB; SDHC 4GB-32GB) - Left and right assignable slider switches - Two assignable rotary knobs - Six assignable three-position switches - One assignable momentary two-position switch - One assignable two-position switch - Comfortable rubber grips on the sides and back - Wide top switch spacing - Adjustable stick tension - Dual ball bearing gimbals - 4 vibration warning types - Home/Exit; User Menu/Servo Monitor buttons - Audio earphone jack (for telemetry alarms) - 6V 1800mAh NiMH battery pack - User stick calibration - Trainer system - Servo speed adjust - 5 programmable mixes - V-tail, Ailvator, winglet, motor mixing - Trim mix - Logic switch (condition switch only) - Internal programmer for S.Bus servos - User menu - Servo monitor (neutral and moving tests) - 2 count up/countdown timers - Integral timer - Model timer - Quick model select ![]() ![]() ![]() ![]() |
