Serpent(蛇仔)推出S100 LT 1/10电动平路车。基于World GT车架的悬挂设计,尾部扭腰采用左右连杆搭配中置液压避震设计,能够有效控制车架的扭动性能。S100 LT 1/10采用2.5mm厚度碳纤底板、可调电池固定座和尾珠差等配置,属于竞赛级产品。这种大比例后驱电动平路车对场地和操控技术有较高要求,对提升操控技术较有帮助,但不建议新手选购这类车架。
SpecificationsClass:: | 1/10th scale World GT | Purpose:: | Competition pan car | Chassis:: | 2.5mm carbon fibre, Lipo-prepared, CNC machined | Rear axle:: | Graphite shaft with ball differential | Drive system:: | 2wd direct drive to rear axle | Shock absorbers:: | Central oil filled shock absorber and lateral monoshock | |
