Yeah Racing 红外线测温枪
11-11-18 23:27| 发布者: admin| 查看: 4320| 评论: 0
Yeah Racing推出红外线测温枪。测量范围自 -50°C至 +260°C (-58°F/+500°F)。尺寸为 95×45x28mm,重量只有65g,适合测量电池表面温度、马达温度和引擎温度。
Description:
  • This Infrared Thermometer is designed measure temperature via electromagnetic radiation.
  • Feature:
  • Material: Plastic
  • Color: Matte Black
  • Specification:
  • Display: 3.5 digit on LCD display
  • Temperature range: -50 ¢XC to 260 ¢XC (-58 ¢XF - 500 ¢XF )
  • Accuracy: ¡ó 2% or 2 ¢XC
  • Repeatability: 1% or 1 ¢XC
  • Response Time: ¡Ø 0.8 second
  • Emissivity: 0.95 fixed
  • Working environment: 0 - 50 ¢XC
  • Relative humidity: 10% - 95RH noncondensing
  • Storage temperature: -20 ¢XC to 50 ¢XC
  • Distance Spot Ratio: 2:1
  • Recommend measuring distance: 20mm to 130mm
  • Resolution: 0.1 ¢XC or 0.1 ¢XF
  • Weight: net weight 65g
  • Size: 95 x 45 x 28mm
  • Power: 2pc AAA batteries ( 1.5V/each)
  • Include:
  • Infrared Thermometer (1 pc)
  • User Manual (1 pc)
  • 详细介绍:
    http://www.yeahracing.com/catalog/yeah-racing-yt0119-infrared-thermometer-p-3153.html
