ProSpeed即将推出他们首款越野车产品Optima K1 1/8 buggy,该车的特点包括尾部Kick up,能够有效提升跳跃性能同时减低跳跃落地后地盘损坏的风险;可快速拆装的差速,可车前部或后部放置的电池固定位置等。
Features - Innovative rear Kick Up, helping to improve take off on jumps and vastly reduce chassis wear - Suspension lower arm mounts that allow the shock angle to be adjusted without needing to correct droop settings - Easy diff access through the bulkheads with removable sections, this gives easier diff access than any other car on the market. - 2PC Engine mount, allows removal of engine whilst leaving the mount in place meaning no need to adjust the mesh when refitting the engine. - Ball Raced Ackermann Plate - Fully captured steering turnbuckle both inboard and out board meaning ZERO popped rod ends. - Bearing captured drive shafts outboard to mean no chance of the CVD pin coming free. - Easy adjustment of brakes using the nut rather than a screw, meaning these can be adjusted from above the car rather than fighting to line an allen driver though all other components. - Front or Rear positioning of the battery pack to allow weight adjustment. - Front upper arms fully supported by steering top plate meaning no additional hinge pin hanger is used. - Airflow and Down force designed Body and wing to give a stable and balanced car.
