Robitronic的Expert充电器家族又多了两位新成员,LD16z 和
LD108z。其中LD16z智能充电器带多种检测机能,能做到自动断电,哪怕是用户使用问题也能检测出来。支持交流和直流输入,内置锂电平衡器,多种充电程序和各式充电接头。 Specifications: - Input Voltage AC: 110-240V - Input Voltage DC: 11-18V - Charge current: 0.1-6.0A - Discharge current: 0.1-1.0A - Max. charging power: 50W - Max. discharge power: 5W - Max. balancer current: 300mA - Max balancer error: +/-0,01V - Number of cells NiXX: 1-15 cells - Number of supported cells LiXX: 1-6 (series) - Number of supported cells Pb: 1-10 (2-20 V) - Weight without cables: 433g - Dimensions: 135 x 112 x 60.9mm ![]() ![]() 而Expert LD-108z是可以对锂电进行充电的简易充电器,全自动充电断电。 ![]() ![]() Specifications: - Input Voltage AC: 110-240V - Charge current: 800 mA x 3 - Number of cells: 2-3 - Display: via 3 LEDs - Operating temperature: 0° C to 40° C - Weight without wires: 100g - Dimensions without cables: 88 x 57 x 35mm |
