Team Durango DEX210 2wd越野车
11-8-1 23:46| 发布者: admin| 查看: 3824| 评论: 1
Team Durango DEX210 2WD电动越野车实车照片公布,原型车在两星期前的世界赛上已经在使用,并获得第五名好成绩。
点击这里参与DEX210新车讨论
- 3 or 4 gear configuration in both rear and mid layouts – with the same gearbox*.
· Aluminium Chassis plate with moulded composite side plates
· Moulded composite shock towers
· Big Bore shocks
· Aluminium FF and RR suspension blocks
· Accepts stick or saddle pack battery in both mid and rear motor configurations
· One body for both mid and rear configurations
· Front end – Adjustable wheelbase, axle trail, caster, camber, toe angle in the kit
· Rear end – Adjustable wheelbase, hub toe angle, camber in the kit
· Dual pad slipper clutch
· Droop screws front and rear
· Captured CVD pins and over-size hub bearings
· Ball Diff as standard. Gear diff will be available as an option
    引用 长风大侠 11-8-3 16:57
    这个角度看过来真的很漂亮····
