Robitronic推出新系列Expert LD充电机。其中15z系列支持1-6 Li-Ion/LiPo/LiFe cells, 1-15 NiCd/NiMH cells and Pb
2-20V,带多款接头。而Expert 45的充电机能更丰富,可对电池进行多种模式的充放电处理。
Robitronic Expert LD 15z
- Built-in AC adapter
- Balance individual cells during discharge
- Fast and Storage mode charging of LiXxx batteries
- Charges various types of LiPoly cells
- Data store/load
- Cyclic charging/discharging for NiXX batteries ![http://www.redrc.net/wp-content/uploads/2011/07/RobitronicExpert-1.jpg](http://www.redrc.net/wp-content/uploads/2011/07/RobitronicExpert-1.jpg)
Technical data:
Input Voltage DC: 11 – 18V
Input Voltage AC: 100-240V
Charge current: 0.1-5.0A
Discharge current: 0.1-1.0A
Max. charging power: 50W
Max. discharge power: 5W
Max. balancer current: 300mA
Max balancer error: +/-0.01V
Number of cells (NiXX): 1-15cells
Number of supported cells (LiXX): 1-6 (series)
Number of supported cells (Pb): 1-10 (2-20V)
Weight without cables: 577g
Dimensions: 138 x 147 x 47mm ![http://www.redrc.net/wp-content/uploads/2011/07/RobitronicExpert-2.jpg](http://www.redrc.net/wp-content/uploads/2011/07/RobitronicExpert-2.jpg)
Robitronic Expert LD 45 - 4 channel multicharger
- Fast and storage mode of LiXX battery
- Data store/load ![http://www.redrc.net/wp-content/uploads/2011/07/RobitronicExpert-3.jpg](http://www.redrc.net/wp-content/uploads/2011/07/RobitronicExpert-3.jpg)
Technical data:
Max. charging power: 50W x 4
Max. discharge power: 5W x 4
Number of cells (NiXX): 1-15 Zellen
Number of supported cells (LiXX): 1-6 (Serie)
Weight without cables: 1090g
Dimensions: 220×150x55mm ![](http://image.rcfans.com/portal/201107/30/162642l52sql24l0qs0q2s.jpg)
