日本Mugen Seiki发布了他们的新一代1/10 200mm油房MTX-5实车照和公布了新车的特性。MTX-5的CAD设计图出现在今年2月德国纽伦堡展览会上,厂方公布了实车照意味着离量产不远了,然而至今也没有公布MTX-5的上市日期,真的让fans们望穿秋水! Technical Information: - Aluminum front/rear bulkhead - Special radio tray module for both lay down servos and receiver including mountable receiver box - New system for faster belt change - New fuel tank mounted from upper side - New front upright system that easily changes the king pin angle by option parts - Aluminum middle shaft - New rear brake system - Fast change roll center - Fast change steering ackerman - New front bumper - Adjustable weight balance - Lightweight gear differentials - New internal gear ratio - New anti-roll bar system - New clutch system ![]() ![]() ![]() ![]() Technical Data: Length: 380mm Width: max. 200mm adjustable Wheel Base: 257.5mm~260.5mm adjustable Tread (F/R): 173mm/169mm Front Caster Angle: 6.4°~13.8° adjustable Gear Ratio: 1st. 7.24:1 / 2nd. 4.69:1 ![]() ![]() ![]() |
