RPM为SC8短卡推出前后A臂
11-3-25 00:43| 发布者: selina| 查看: 5762| 评论: 5
Rear A-arms for the SC8 & RC8
Rear SC8 & RC8 A-armsWhether you抮e out having fun bashing or in the middle of the A-main at a national event, nothing is more frustrating than breaking an A-arm. That抯 where RPM steps in. RPM A-arms for the Associated SC8 & RC8B are designed to prevent that from ever happening again. These A-arms are tough as nails and designed to take some serious punishment! Every aspect of the design on these arms is there to either improve strength or durability. Additionally, we抳e cleared the A-arms in areas known to rub on the stock A-arms, allowing extra droop for more suspension travel over rough terrain or big jumps.
Exclusive features of RPM A-arms include: Molded-in shock mounts which means no more lost screws or extra weight from those screws on the arms (each RPM Rear A-arm is actually 3 grams lighter than stock, saving 6 grams of unsprung weight!). Elimination of the stock lower shock mount pin in favor of a new 5-40 screw, which eliminates .004
12
    引用 hhbonus 11-3-25 20:17
    lx lx的lx 。。。 都是op大家 哈哈
    引用 sweeper 11-3-25 16:57
    这个太好了,就等这个了
    引用 leozhaoniu 11-3-25 14:43
    这个好 什么时候能上市
    引用 x蜗牛增压x 11-3-25 12:51
    就等于跨度大了!
    引用 zhukenda123 11-3-25 02:07
    等国内上市...
    查看全部评论(5)
