Pro-Line RB5 BullDog车壳
11-2-17 23:12| 发布者: admin| 查看: 5210| 评论: 0
Pro-Line的BullDog车壳相信大家都听说过,这个系列的车壳较原厂车壳的空气动力学性能更佳。BullDog的最新款式是给Kyosho(京商)的RB5 1/10电动越野车使用的,车壳的设计能够让车子在减速的时候获得更多的转向性能,而且车壳的重心进一步降低。
Pro-Line have released their BullDog body for use with the Kyosho RB5 1:10 buggy. Providing performance that has, at times, been deemed an unfair advantage, BullDog bodies now set the standard in performance. The advanced cab forward design generates unmatched off-power steering, while the low profile rear deck feeds the wing with clean air flow. Made from durable / genuine Lexan, the super-low styling giving your RB5 the lowest center of gravity (CG) possible.
Source: Pro-Line [prolineracing.com] & Redrc.net
