HoBao Hyper Star 越野车
11-1-27 00:51| 发布者: admin| 查看: 4116| 评论: 1
HoBao(合宝)发布了Hyper Star 1/8 Buggy(越野车),这是一辆基于Hyper 9平台开发而成的新车,最大的特点是该车同时推出油动版本和无刷电动版本,相信新车会在纽伦堡展会上亮相。
NITRO edition Specifications
•PIVOT BALL SUSPENSION SYSTEM •CROSS SHAPE LINKAGE ARM FOR THROTTLE AND BRAKE UNIT •CERAMIC BRAKE PADS •FRONT AND CENTER SPIDER DIFFERENTIAL •FRONT & REAR UNIVERSAL DRIVE SHAFT •4MM LIGHT WEIGHT 7075 CHASSIS •FRONT & REAR ALUMINUM CHASSIS STIFFENER WITH LASER ETCHED LOGO •NEW FRONT & REAR ANTI ROLL BAR •NEW FRONT & REAR SHOCK TOWERS FOR MORE TUNING OPTIONS •NEW RADIO BOX FOR EASIER ACCESS •NEW STRONGER SERVO SAVER FOR DURABILITY
•CENTER UNIVERSALS •REDESIGNED CENTER DIFF AND BRAKE COVER •NEW REAL BRAKE BLOCK •NEW FRONT COMPOSITE CHASSIS PLATE •NEW CENTER CHASSIS DIFF PLATE •ALUMINUM PIVOT BALL WITH STEEL THREADED ENDS
Electric edition Specifications
•PIVOT BALL SUSPENSION SYSTEM •FRONT AND REAR UNIVERSALS
•NEW REAL SUSPENSION
•3 OIL FILLED DIFFERENTIALS
WITH STEEL INTERNAL GEARS
•CNC MOTOR MOUNT
•CENTER UNIVERSAL
•MOLDED BATTERY TRAY
•17MM HARD COATED SHOCKS WITH THREADED
SHOCK BODIES
•FRONT & REAR SWAY BARS
•MOLDED TRANSPONDERMOUNT
•FULLY ADJUSTABLE SUSPENSION
•LAY DOWN STEERING SERVO SYSTEM
•ADJUSTABLE CASTER,CAMBER FRONT WIDTH &
ACKERMAN
•1 PIECE WING
 The car is built upon the proven Pivot Ball Steering concept, front & rear spider diffs and a 4mm lightened 7075 alu chassis. The new parts list is long; F&R anti roll bars, F&R shock towers, new radio box, beefier servo saver, re-designed center diff protector, brake block etc.
Link: www.hobao-racing.com
RCFans会员报道:http://www.rcfans.com/bbs/forum.php?mod=viewthread&tid=323124&extra=page%3D1
    引用 济南16 11-1-27 01:10
    http://www.rcfans.com/brand到货了吗?
