Kyosho(京商)推出一款1/10入门级油动越野车,DBX2.0,市场上十分之一比例的油动越野车较为稀罕,Kyosho这款产品其实是以1/8越野车为蓝本开发而成的,车架架构,设定都与1/8越野车一致,轴距也和1/8越野车没太大差别,甚至可使用1/8的轮胎!厂家力求让入门级玩家能感受到真正越野车的性能、调教,通过玩这款入门产品累积足够的buggy知识,为日后进入更高级别的越野车作准备。DBX2.0搭载一颗GXR-18SP引擎,2.4G遥控,是一款高性价比的RTR产品。详细资料在本文内。
Features
The long stroke 4-wheel independent suspension and full-time 4WD drive-train powered by the 18-size engine means nothing can stand in your way. Fully-factory assembled and in a Readyset package for instant off-road excitement.
- Big Bore Shocks – Equipped with large capacity oil shocks as standard. Soaks up bumps with ease and provides smooth landings. Features threaded shock bodies for chassis height setting.
- 2.4GHz Syncro System – The all new Kyosho 2.4GHz transmitter, ultimate safety and function included with all DBX 2.0 Ready Sets.
- Duel Brake Disks – Brake disks are equipped in the front and back of the center differentials providing reliable braking power. Enables separate adjustment and setting of front and rear brakes.
- Finished Body – Pre-cut body features sharp 3-color printed color scheme. Cab forward design of the body delivers optimal down force and airborne stability as well as increasing maximum speed.
- Multipoint Adjustments – Design features multi-point setting adjustments such as chassis height, camber, tread, front and rear toe-in etc.
- Large 1/8 Wheels & Tires – The DBX 2.0 comes equipped with 1/8th size wheels and tire combo, resulting in a larger footprint and improved handling. Giving you the 1/8th scale feel and look in a 1/10th package. All current standard 1/8th wheels and tires will fit the DBX 2.0 standard 17mm hex.
- Shaft Drive – The drive shafts run through the center for chassis to give you better lower CG and optimum weight balance.
- Fully Digital Servos – Equipped with digital servos for great response.
- Dirt Proof Radio Box – Dirt-proof radio box protects the receiver and battery. Can be attached or removed from the chassis with just four screws.
- Wide Stance – Long span suspension arms create the wide tread on the double wishbone 4-wheel independent suspension system for superior stability.
- Fully Interchangeable – Front / rear and left / right suspension arms, front / rear knuckles and front / rear shock stays are all interchangeable. Newly designed suspension with maintenance-friendly ball connect system.
- Power House GXR18SP – GXR18 engine mounted on 1/10 chassis that is normally seen with 12-15 size engines. Equipped with recoil starter, large cylinder head and tuned type muffler.
- Massive 105cc Fuel Tank – Includes newly designed 105cc fuel tank to supply the large 18-size engine with plenty of runtime. Delivers stable fuel supply even under severe driving conditions. Can deliver run times of more than 10 minutes.
New Kyosho Syncro 2.4GHz System
- Easy Access – The trim, EPA and servo reverse settings are located on the top panel of the radio for easy access, visibility, and to prevent accidental changes by bumping, knobs normally located on the front of other radios. The advanced nature of this design is ideal for beginners and intermediate drivers. Two position trigger neutral point allows a 70/30 or 50/50 neutral position for the throttle/brake trigger, making it ideal for both EP and GP vehicle.
- 4 Channel Receiver – The advanced receiver design features four channels, which allows for future development and expansion. It also includes a fail-safe feature that will maintain control of your vehicle in the rare event of signal loss.
- Ergonomic Design – The advanced ergonomic design is very comfortable and delivers superior control. The transmitter is powered with just four AA-size alkaline batteries, which makes the Syncro balanced and lightweight, which virtually eliminates the fatigue common with heavier radios
Source: Kyosho [kyoshoamerica.com] & Redrc.net |
