Associated RC10T4.1 Factory Team kit
10-7-5 16:20| 发布者: admin| 查看: 4088| 评论: 0
assot4-1-1RC10T4 算是一辆老车,首次发布是在2003年,但是由于该车设计出众,多年来在美国等赛场夺得多个冠军头衔!包括7次美国ROAR全国冠军,为了延续RC10T4电动卡车的辉煌,AE推出了RC10T4.1厂队版!全面支持锂电和无刷设备,全车使用了多款升级零件,包括Team aluminium rear hubs, V2 slipper, Hi-Flow T4车壳,优化的悬挂,让T4.1性能再次提升,详细资料和照片在本文内。 RC10T4.1 Factory Team Kit Features: - Factory Team 0.5 degree aluminum rear hubs with oversized outer bearing - Ball differential with light-weight outdrives - Factory Team V2 hard-anodized threaded shock bodies with bleed-screw caps - V2 slipper assembly with high-rate spring for more consistent slipper clutch adjustments - JConcepts Hi-Flow T4 body - JConcepts Double-Dees rear tires in green compound and Carvers front tires in blue compound - CVA joints with pin retainer clips - Carbon fiber battery strap with blue aluminum thumb screws - Blue titanium turnbuckles - Optimized suspension setup for use with LiPo batteries - Suspension mounts for 4°, 3.5°, 3° and 2.5° rear toe included - Complete set of precision ball bearings - Factory Team blue aluminum hinge pin brace, milled motor plate, servo mounts Source: Associated [rc10.com] & Redrc.net
