Spektrum DX3S 遥感版
08-10-10 23:22| 发布者: admin| 查看: 2133| 评论: 0
Spektrum的新款DX3S代表了遥控界的最新科技。它的最大特点就是通过信号双向传输,能在遥控器上看到装在车子上的感应器的数据。此功能无论对高手还是新手都非常有意义,可以检测引擎的转速,马达的温度,等等。而且,无需在遥控器安装任何附加设备,一切数据均可在大屏幕上清楚显示。
Key Features
* Integrated telemetry with graphically depicted gauges on transmitter
* Monitor your engine or motor’s operating temperature in either Fahrenheit or Celsius
* Never let a low battery stop you in your tracks – the DX3S and integrated telemetry lets you watch over your receiver pack’s voltage to keep you in the running
* Keep tabs on your engine’s operating range-safe high-rev operation
* Includes SR3300T 3-channel receiver with built-in telemetry
* Includes free bonus SR300 3-channel DSM sport receiver
* Rolling selector user interface for fast, easy programming and setup
* 10-model memory
* 10-character model naming
* 3 grip sizes (small, medium, large)
* ModelMatch
* Expert and standard modes
* Digital trims
* Throttle Punch
* Steering dual rate
* Travel adjust
* Servo reverse
* Sub trims
* Exponential
* 3-timer functions
* Aux channel mixing
* Telemetry alerts
* Buzzer adjustments - high, low & off
* Screen contrast
* Transmitter battery alert
* Right hand configuration (only)
