HPI的Sprint平台已经有一些年头了,现在厂方为它装上Flux无刷系统重新发售。车子是RTR版本,悬挂系统具有一定的可调教性。 使用较宽的后胎,配合多款怀旧车壳,如Ford Mustang GT,绝对是跑街的好手。
CARATTERISTICHE SPRINT 2 FLUX
- Flux Warp 5700kv brushless motor provides high performance, efficiency, long motor life, reduced maintenance.
- Flux Motiv ESC for smooth and efficient motor control.
- Fully adjustable suspension with control over important settings like camber, caster, toe-in and more.
- A belt driven 4 wheel drive system guarantees smooth power transfer and high grip on a wide variety of paved surfaces.
- Race proven suspension with oil filled shock absorbers for excellent handling.
- All important chassis and suspension parts are made from high quality, high impact nylon which makes the Sprint 2 Flux extra tough!
- HPI Bodies are made of high quality, impact resistant polycarbonate and come pre-painted, pre-cut and pre-decaled for great looks!
- Sealed front and rear gear differentials reduce the need for time-intensive diff rebuilds.
- Adjustable droop for better handling, especially on high grip tracks.
- Full ball bearings for a smooth, free-flowing transmission.
- Ball bearing steering bell crank for precise driving.
- Gear differentials with metal outdrives for increased durability.
- Gearing has been optimized for the Flux Brushless System.
- Reliable TF-1 radio super narrowband AM system.
- Ready-to-Run chassis built to factory specs by the assembly experts at HPI.
- Add your own battery pack, charger and AA transmitter batteries.
