Team Associated继RC8Te和SC8e之后,推出RC8e 1比8电动竞赛级越野车。车子基于优秀的RC8平台。针对电车的特性,AE开发团队特地对车子做了开发,使其强度、耐用性、过弯能力和操控性都与油动的RC8很类似。
RC8e Kit Features: - Molded battery tray supports two ROAR-approved 1:10 scale size 7.4v LiPobattery packs with room for foam pads - Receiver box, servo, and battery tray are removable in one piece for easy maintenance and cleaning - Convenient wire routing keeps critical electronic wires out of drive-train components and simplifies disassembly - Includes pinion gear (15T) and molded composite spur gear (46T) - Rigid one-piece motor mount utilizes standard motor screw mounting pattern - Large elevated speed control mounting area allows for easy screw mounting of common speed controllers - Upgraded dual bellcrank steering for more consistent steering and reduced bump-steer - 16mm “Big-Bore” molded composite shocks with preload clips - Hard anodized 7075-T6 aluminum chassis - 3mm aluminum shock towers - Durable 10mm thick suspension arms - Rear molded CVA boots to keep dirt and mud out of rear joints See next page for more features! - Alloy steel turnbuckles - Caster blocks adjust 14, 16, or 18 degrees with molded inserts - Adjustable suspension pivot bushings for different pivot height options - 4.30:1 ratio gearboxes - 3.5mm light CVA drivetrain - Pre-drilled wing with adjustable angle and location - Blue aluminum drive hexes - Blue aluminum nylock wheel nuts - 83mm Factory Team wheels (#89296) - Speed control mounting area includes convenient switch-mounting boss - Utilizes 3 hook-and-loop straps to secure LiPo batteries into battery tray - Enclosed receiver box to protects electronic components - Unpainted RC8e body with cooling scoops (#89523)
