意大利GRP公司的技术总监是著名的Mario Rossi。这款1比8非改装竞赛引擎使用高质量材料制造,工序严格。引擎的温度控制系统(TCS)可以阻止热量向化油器传递,减少因此产生的进气干扰。
引擎的零件都可以跟GRP的改装系列引擎互换,这意味着您可以随意更换升级零件以改进性能,而无需整个购买新引擎。引擎还配备塑料盒子和贴纸。
Features
- .21 Non-tuned racing engine for 1/8-scale buggies
- Aluminum 7.5mm carburetor
- Produced in Italy by GRP, under the direct technical supervision of Mario Rossi
- Engine components are interchangeable with GRP tuned engine parts for easy performance improvement
- Features true ABC construction
- Comes in a GRP plastic box complete with decals
Product Specifications
- Type:1/8 Buggy
- Displacement:.21 cu.in.
- Bore:16.27 mm
- Stroke:16.79 mm
- Engine (Only) Weight:355 g
- Crankshaft Threads:14 mm
- RPM Range:max 38.000 RPM
- Fuel:Nitromethane
- Cylinder Type:ABC
- # of Ports:5
- Carb Type:Aluminum
