MST(Max Speed Technology 得隆科技)推出RMX EX S PRO竞赛级1/10 RWD后驱漂移遥控车,轴距257mm(+-3mm)。 特性: -The newly designed ATK V2 Front steering block is used with a new Ackermann setting that provides aggressive and flexible steering at the beginning of the turn and can handle larger drifting angles in the later stages of the turn capable of stable driving during high-angle drifting. -The new design THA adjustable short arms are used in the rear with long-type suspension arm mounts to increase rear roll and improve flipping speed and corner exit acceleration. -All-new designed rear aluminum arm mount -2 paired with newly designed elongated arm mount +12 compatible with +13. -Free choice of preferred high/low center of gravity control modes: *High center of gravity mode for aggressive handling. *Low center of gravity mode for stable handling. -Equipped with new-designed rear spur-gear-driving gearbox is switchable for RMX and RRX drive mode. -Utilizes new gear differentials with #3000 silicone oil for optimal differential performance. -FRP chassis with 2.0mm thickness maintains moderate rigidity. -Dual-piece FRP upper deck with 3.5mm thickness enhances chassis rigidity. -New designed front damper stay. -New designed front upper deck connecting bracket. -New designed DK-RWD front/rear short spring set. -Lightweight quick-release battery mount. -New designed lightweight front bumper/rear handle. |
